Several Questions/Problems Related to TE0711
trident_
Joined Apr 21, 2023
1. I have a 5V-50ohm pulse signal coming into the FPGA (operating @3.3V), how do I reduce this signal to a lower voltage for the FPGA and not worry about reflections. (zener diode?). I also want to dummy proof this where if someone puts in an AC signal or high-voltage signal it doesn't fry/mess up the FPGA.
2. I also need to output a 5V-50ohm signal to a BNC/SMA connector from the same FPGA. How do I do this? Do I need to drive it or what does this entail?
3. I also need to output a signal (I can define it) to 10+ FPGAs (TE0711) on a backplane (~1 foot long). Will a single FPGA have enough power to output to several FPGA inputs? Do I need a driver circuit? If I do need a driver, is there a way where I can monitor the driver snd feed it back into the same FPGA? What would all of that entail?
4. I have a 24V signal coming from the backplane to my FPGA, how do I reduce this voltage? Can I use a step-level shifter, a zener, or is there another component that would be better?
I am writing the software for this board and I am more of a software person than a hardware, so I apologize if some of these questions are pretty easy/simple.
35,228
Welcome to AAC!
Just that you know, AAC Forum is a free community run service for electronics hobbyists and professionals alike.
There are 1.7 million messages, 170,000 threads and 800,000 members and counting.
Moderators have a tough job keeping on top of things and keeping threads well organized.
Moderators depend on AAC members to assist in the smooth operation of the forums by following directions of moderator requests.
You, as a new member, can assist us in this endeavour.
Initial questions pertaining to the same device should be posted on the same thread. If it would be better served to create a new thread we can do so when and if it becomes warranted.
