Sinusoidal signals - expressions - maths - several questions
atferrari
Joined Jan 6, 2004
5,029
It is not homework, just 73yo + quarantine.
Reading two ongoing threads in this forum I realized that, shame on me, I forgot the basics. By searching in the Web I got more doubts.
I would appreciate if answers are given in the order below with units.
a) Our AC from the mains is ideally sinusoidal, nominal 220 V - 50 Hz. Is it RMS, right? How do I express that?
b) I could set my Siglent generator to output these four sinusoidal signals. How do I express each?
Amplitude 2 V - 750 Hz - offset 0 V.
Amplitude 3 V - 650 Hz - offset 0,5 V.
Amplitude 1 V - 350 Hz - offset 3 V.
Pk to pk 3 V - 400 Hz - offset 6 V.
c) Applying a sinusoidal signal of 2 V amplitude - 1 Khz - to the both inputs of an analog multiplier gives the square of the function.
Could you by visual inspection estimate (¿?) the outcome (amplitude and frequency)?
d) What if I apply the same signal with 2 V of amplitude - 440 Hz - and 5 V offset?
e) If I wanted to multiply c) by itself and d) by itself, with my calculator, what is the right procedure?
Thanks for any help.
Papabravo
Joined Feb 24, 2006
22,113
I guess for starters it might help to remember that all sinusoidal signals are expressed in terms their peak amplitude and phase. DC offsets add to the "0-level of the signal" and have the same effect on all points of the signal.
a) The signal from the mains is 220 VAC(rms). To get the peak value you multiply the RMS value by √2, or 1.414...., and you get 311.126 VAC(pk). The frequency of a sine wave is usually represented by converting the frequency from Hz (Hertz) to radians/sec. You do this by multiplying the frequency in Hz., by 2π, and you get 314.159 radians/sec. We won't worry about phase angle for the moment. What comes out of the wall is:
311.126*sin (314.159*t) VAC for all t in seconds​
The sine function takes values from -1 to +1 and the voltage will go from -311.126 to +311.126 as t goes from 0 to .020 seconds (1 cycle at 50 Hz.)​
b) 2nd verse - same as the first
2V@750 Hz + 0 VDC would be --> 0 VDC + 2 sin (4712.4*t) VAC​
3V@650 Hz + 0.5 VDC would be --> 0,5 VDC +3 sin (4084.1*t) VAC​
Give the other examples a try and see how it goes. Ask again if you hit a snag my friend.
35,210
In mathematics, we tend to write
y = A sin(ωt + θ)
Assuming phase angle θ is zero, in electricity and electronics we prefer to substitute
ω = 2πf
Hence we write
V(t) = Vdc + V sin(2πft)
becomes
0.5 + 3 x sin(650 x 2π x t)
atferrari
Joined Jan 6, 2004
5,029
a) The signal from the mains is 220 VAC(rms). To get the peak value you multiply the RMS value by √2, or 1.414...., and you get 311.126 VAC(pk). The frequency of a sine wave is usually represented by converting the frequency from Hz (Hertz) to radians/sec. You do this my multiplying the frequency in Hz., by 2π, and you get 314.159 radians/sec. We won worry about phase angle for the moment. What comes out of the wall is:
Gracias Papabravo!! Short and to the point. I appreciate that.
atferrari
Joined Jan 6, 2004
5,029
y = A sin(ωt + θ)
ω = 2πf
Hence we write
becomes
Gracias MrChips! I dodged that expression for years.
y = A sin(ωt + θ)
ω = 2πf
Hence we write
becomes
Do you think it would be better to express a sinusoid in the form
y = A cos(ωt + θ)
rather than using sine function?
My rationale being that if you do a Fourier analysis on a signal the phase that's returned is relative to a cosine rather than a sine.
I know it's just a π/2 phase shift but I've always felt that it would tie in much more neatly with frequency domain analysis if cosines where the standard way of representing sinusoidal signals. Is there a particular reason that sine functions seem to be the standard in power/electrical engineering?
35,210
y = A cos(ωt + θ)
Good question. I don't know the answer.
y = A cos(ωt + θ)
Good qeustion but generally we like to have the origin of signals from a zero (equilibrium) rest point when looking a phase shift.
https://mathbitsnotebook.com/Algebra2/TrigGraphs/TGShift.html
I think I see what you mean. It's easier to read phase differences between sinusoids where the sinusoids cross the time axis? I still don't think it's a big deal whether they're sines or cosines though - if I understand you correctly.
MrAl
Joined Jun 17, 2014
13,817
Sometimes the cos(wt) form rather than the sin() form simplifies some circuit analysis that involve inductances. Sometimes it is better that the RESPONSE starts at zero rather than the excitation.
Also, you can convert a sin() form into a cos() form or vice versa.
You can even convert a sum like:
A*sin(w*t+ph1)+B*sin(w*t+ph2)
(or any combination of sin or cos terms)
into a single sin() or cos() form that usually includes a phase shift part also.
This means that you can convert a sum of any number of terms with the same frequency into a single sin() or cos() form.
MrAl
Joined Jun 17, 2014
13,817
For the multiplication of two regular sines we have this identity:
A*sin(t*w1+ph1)*B*sin(t*w2+ph2)=
(cos(t*w2-t*w1+ph2-ph1)*A*B)/2-(cos(t*w2+t*w1+ph2+ph1)*A*B)/2
Notice the phases are multiplied while the frequencies are added.
