When I do:
sudo update-alternatives --config java
I get:
Selection Path Priority Status
0 /usr/lib/jvm/java-6-openjdk-i386/jre/bin/java 1061 auto mode
1 /usr/lib/jvm/java-6-openjdk-i386/jre/bin/java 1061 manual mode
* 2 /usr/lib/jvm/java-7-openjdk-i386/jre/bin/java 1051 manual mode
I am new to java. From my reading, I understand that this means version 6 is the default?
How do I set version 7 as default and make it auto mode?
I tried what I found here:
http://askubuntu.com/questions/308663/how-to-set-the-default-java-version
Adjusting for my path
sudo update-alternatives --install "/usr/bin/java" "java" "/usr/lib/jvm/java-7-openjdk-i386/jre/bin/java" 1
And I get:
update-alternatives: warning: forcing reinstallation of alternative /usr/lib/jvm/java-7-openjdk-i386/jre/bin/java because link group java is broken
Is this something to sorry about?
It looks like the default is now changed but auto mode is still set for 6
bruce@debian1:/$ sudo update-alternatives --config javaThere are 2 choices for the alternative java (providing /usr/bin/java).
* 2 /usr/lib/jvm/java-7-openjdk-i386/jre/bin/java 1 manual mode
How do I change that?
I get:
And I get:
