To keep the rapidly cooling wire at operating temperature a little longer while you measure using this method, sandwich the wire in some fiberglass insulation and use the min/max feature on your meter to capture the data.Reasonable concern. Put a suitable switch in parallel with the meter and close it before powering up the circuit. Then after the wire is at temp, open the switch and make your measurement.
