To keep the rapidly cooling wire at operating temperature a little longer while you measure using this method, sandwich the wire in some fiberglass insulation and use the min/max feature on your meter to capture the data.Reasonable concern. Put a suitable switch in parallel with the meter and close it before powering up the circuit. Then after the wire is at temp, open the switch and make your measurement.
1 Series Oscilloscope | Test & Measurement | 0 | |
| M | Fluke 73 series 1 Multimeter repair | Technical Repair | 8 | |
| 7 | 7400 series's | Digital Design | 18 | |
Looking for help with wiring PJ Bass (Series/Parallel blend bypass) | General Electronics Chat | 1 | |
series resistors Vs. lowering the voltage | General Electronics Chat | 9 |
