SEPIC converter possible design?
Senorjohnny
Joined Feb 18, 2018
47
Specifications:
Vin = 9V
Vout = 1.5V - 12V
I've built a prototype based on the LTSPICE model. It doesn't seem to work as intended, my inductors are getting 18V each instead of 9V and Vout = 0V.
Any possible solutions?
Thanks in advance.
ericgibbs
Joined Jan 29, 2010
21,439
hi j,
I have added a Load resistor 100R and I get +10Vout.
E
EDIT:
This what I get by adding a simple 25K Pot for basic control.
Looks OK.
E
Senorjohnny
Joined Feb 18, 2018
47
hi j,
E
EDIT:
Looks OK.
E
Thank you. I seem to have solved my Vout problem, i had the pins on the Schottky diode wrong. However now, I am getting too high of a Vout(40+V) . What could be the problem?
ericgibbs
Joined Jan 29, 2010
21,439
hi johnny,
Is the Vout not controllable ie: stuck at 40V.?
It is possible that the LT1370 IC has blown.
Is the circuit the same as that LTSpice circuit diagram you posted .
A clear photo of the psu may give us an idea of what is wrong.
E
Senorjohnny
Joined Feb 18, 2018
47
hi johnny,
E
Hi Eric,
Yeah, the Vout is not controllable. The circuit is exactly the same as the LTSpice circuit diagram.
Thank you for the quick response.
Regards,
J
Senorjohnny
Joined Feb 18, 2018
47
Hi J.
Try a range of load resistor values, lets know what results you get.
E
Hey Eric,
I managed to get it working. So far i've tested on 100R, 500R, 1K and 2K. Also, i was able to fix the feedback control, I did not connect the wiper to the pin.
@47K ( Potentiometer )
Vout @ 100R = 9.98V
@ 500R = 10.17V
@ 1K = 10.21V
@ 2K = 10.21V
@1K
Vout @ 100R = 1.42V
@ 500R = 1.42V
@ 1K = 1.42V
@ 2K = 1.42V
I think i should swap out the potentiometer for a higher value one, that should give me the 12V i want.
What would you recommend me to do next? In term of data collection.
Thank you,
John
ericgibbs
Joined Jan 29, 2010
21,439
hi John,
What value resistor do you have connected from the Vout to the top end of the 47k pot.?
E
EDIT:
This should give the required Vout range.
Senorjohnny
Joined Feb 18, 2018
47
hi John,
E
EDIT:
Hey Eric,
That resistor is 1K.
How do i know much current is the LT1370 chip drawing? Is it the "Quiescent Current: 4.5mA" mentioned in the datasheet?
J
ericgibbs
Joined Jan 29, 2010
21,439
hi J,
Off Load the LT1370 would draw only 4.5mA from the power supply.
To measure the LT1370 you would connect an Amp meter is series with power pin of the LT1370.
E
Senorjohnny
Joined Feb 18, 2018
47
hi J,
E
Morning Eric,
How should i test the efficiency of the circuit?
Would obtaining the Vout while varying the load(output A) be correct?
I'm thinking of varying output A from 0 to 0.8A, by using resistors in series as load.
John
ericgibbs
Joined Jan 29, 2010
21,439
hi j,
Measure the input current from the 9V battery and the current thru the Load resistor at different Vout voltages.
Post what you measure.
E
ericgibbs
Joined Jan 29, 2010
21,439
hi Johnny,
This sim is for 9Vin and 9V out, with a 100R Load, 90mA
Try it with the actual project.
NOTE: the input current will fluctuate due to the switching action of the IC/MOSFET.
The images of the pop up menu show the LTS values for Power.
Using the two mWatt values you should be able to calculate the Eff%, at those V and I values.
It will change as the load changes.
E
Senorjohnny
Joined Feb 18, 2018
47
hi Johnny,
E
Hi Eric,
Sorry it took so long, my order for the resistors just arrived. This is what I have gotten from my project. Does it look right? The load values were calculated using V=IR , V=12, I = 0 - 1 .
Thank you,
J
ericgibbs
Joined Jan 29, 2010
21,439
hi Johnny,
Downloaded your results image, will look them over, get back to you.
E
EDIT:
Your table of results is incorrect.
Look at my image Red columns .
Note: the Input current will be 'chopped' due to the switching action of the converter, so a regular ammeter will give incorrect results.
Update:
Added a LTS sim for the circuit when Rload =12R and Vout =3.7v [ your last table reading]
