Sender and gauge compatibility
BillB3857
Joined Feb 28, 2009
2,573
Can you give a better explanation for the gauge reading 33-240? Does that mean a series resistance of 33 ohms for Empty and series resistance of 240 ohms for full reading? At what voltage?
Jonathon Morris
Joined Oct 4, 2015
2
There are just 2 wires, no supplied voltage for sender but gauge runs on 10-16 volts. 0-700 700 empty on sender, 33-240 240 empty on gauge
Brownout
Joined Jan 10, 2012
2,390
I'm more confused than before. Your guage reads 33 - 240...what? Please provides all the details. Most of us won't guess and won't hang around for the details to drip out.
18,108
A traditional fuel gauge sender is a simple variable resistor. It's a fine wire wound around a support, with a spring-held wiper that moves with the float. Depending where the wiper touches the wire windings, indicating the float position, a varied resistance is seen at the output.
I have no idea what you are talking about with your gauge.
MikeML
5,444
How many terminals on the gauge? Two or Three?
If two, is is wired like this?
Be advised that it is really hard to make this work. You really need to get a sender matched to the gauge...
Brownout
Joined Jan 10, 2012
2,390
If the guage is looking for 33 - 240 ohms and say, 14V, or eqivalently 424 - 58mA, I suppose you could use a voltage/current converter calibrated to those current outputs.
PS: The thread in the link uses a voltage scaler, so I'mclearly out of my league here.
