Self powered PC microphone preamplifier
Dever
Joined May 2, 2022
35
I was wondering how would behave this circuit:
I wanted to create electret microphone (Q1) amplifier that is powered via microphone input from my PC sound card (around 2.5V - I will check later). Is it going to work properly? I'm not sure about connection output of opamp.
Audioguru again
Joined Oct 21, 2019
6,826
Your PC sound card already has a microphone preamp on it. Why do you want to add another amplifier that will probably overload the input of the sound card preamp?
Your new circuit must use an opamp that works when powered with a low voltage and a very low current.
The inductor will probably pickup interference and cut all audio low frequencies from the mic.
Dever
Joined May 2, 2022
35
My integrated sound card has weak microphone amplifier. In its settings I have to choose +30dB digital amplification. However it also amplifies all noise. I have tested mic input with other preamplifier, which I built and it worked. Anyway, I’m going try self powered version.
You are right. I can get rid of inductor or just leave it for opamp supply.
Audioguru again
Joined Oct 21, 2019
6,826
The 1k resistor that powers your mic has a very low resistance that reduces the mic output level. Try a higher resistance.
On my mic circuits I use a 9V supply and a 1k resistor with a capacitor to ground as a filter, then a 10k resistor to load and power my electret mic.
