I have a project that requires an operational amplifier with an output capable of a peak to peak voltage of at least 10V from d.c. to 1MHz (sinewave), operating from a single rail supply. Fortunately the op-amp will be operating close to unity gain and the load impedance >100kΩ.
Many supposed high frequency op-amps I’ve looked at - their peak-peak output voltage drops close to zero at around 1MHz. Since my circuit requires four op-amps, a device in a dual/quad package would be good.
Any suggestions gratefully received.
