- Joined Jan 23, 2018
- 19,630
Almost all of the contactor motor starters were used on production equipment, primarily "Big Three" companies. To keep production lines running theydid repairs themselves in areas that they were able to service. They were also prompt to report any failures in the systems that they had purchased.
For those systems that utilized electric heaters and cycling temperature control the standard approach was a mechanical contactor for the enable/disable function and an SSR for the duty cycle control, with the overtemp sensors in series with the coil of the contactor.
The one single pole contactor that I saw failed was switching DC power to a 50 KW lighting load. That contactor did have magnetic blow-outs but it still welded shut on the "Make" operation. That was about 140 volts from a massive battery pack that my employer had sold them years earlier. That was in a vehicle crash test installation, and it was for one of quite a few high power lighting arrays.
The utility company did not want to provide service for 400 KW in that section of the building that would only be used a few minutes each day, so we sold them battery power units, which worked out quite well.
