Second opinions requested on a solenoid issue?
Papabravo
Joined Feb 24, 2006
22,111
I did find this equivalent.
https://www.amazon.com/gp/product/B007Z7MNEM/ref=ewc_pr_img_1?smid=A1AESWW2VFKG60&psc=1
Papa, are you feeling OK? we've several reports about replies like one above. It could be interpreted as antagonistic.
I don't understand your question and I'm appalled you would think that. I'm fine BTW, thanks for asking. You asked for search terms, and that is what we called them back in the day. It seems like a perfectly normal description of the function of the device and was not in any way intended to be directed at any person. I'm not sure how you can be antagonistic to a thing, but there are lots of things I don't know anything about.
Top google Hit for "solder sucker"
https://www.zoro.com/aven-solder-su...erm=4586131723107564&utm_content=All Products
djsfantasi
Joined Apr 11, 2010
9,237
I might give it a try.
Papa, are you feeling OK? we've several reports about relies like one above. It could be interpreted as antagonistic.
That’s the exact one I bought and use.
That does look interesting. If it weren’t for the price and my current investment, I would try it.
Reloadron
Joined Jan 15, 2015
7,931
This is the one you want. You can use this with one hand by turning your wrist and pushing the yellow plunger against a hard surface.
https://www.amazon.com/EDSYN-The-Or.../B006GOKVKI/ref=asc_df_B006GOKVKI?FORM=SSAPC1
What I don't know is how you can hold the iron and suck the solder at the same time.
There is also the possibility of having a desoldering station with a footswitch to activate the suction. In this arrangement the iron tip is hollow, and it is connected to a vacuum pump. Seems like this would be more convenient for you.
I used one of these for years and somewhere around here I still have it. I have used it and cocked it one handed. Grasp the blue tube and just push it against the side of the bench or turn it over using your wrist and push down against the bench or table top. Then came the desoldering stations with button on handle to activate the pump.
Ron
Wendy
Joined Mar 24, 2008
23,813
I'll let ya'll know, I ordered one after my last post.
I've released my inner OCD on my money, I'm not hurting by any means. I try very hard not to waste it. I don't consider experiences where I learn something a waste. I'm trying to get back into soldered projects.
Papabravo
Joined Feb 24, 2006
22,111
I do admire your resolution and determination.
