Schmitt trigger problem
patpin
Joined Sep 15, 2012
405
Hello I try to convert an analog signal to block waves when the signal comes at a certain voltage.
On the sim on the green signal you see the 4 small positive peaks I want to be causing the output of U3 go high.
Don't mention the rest of the circuit.
But I do not succeed with this Schmitt trigger. Any idea?
patpin
Joined Sep 15, 2012
405
Thanks, This looks much better. In fact I want to use a LM358 but this model was not working (either) and I took the LM324-model instead. Do you think this will make a difference once realised?
patpin
Joined Sep 15, 2012
405
Hello again. I tried your way here. I saw you changed also things around U1. This one has to stay as it is since I need that signal. So after putting U1 periphery back (as in .asc) and with my PWL, U3 doesn't creates the 4 square waves as I would like. Can U check what's wrong.
eetech00
Joined Jun 8, 2013
4,725
Hi
Try this LM324 model attached. The zip file include the test file shown below
eT
