Schematic Design Review - Microcontroller, USB, Sensor & Other Interfaces
hussainyakub
Joined Aug 3, 2017
8
I would really appreciate if I could get a review and suggestions for my schematic design containing ATmega328p IC, USB to UART (CH340G), some basic interfaces like button, RGB LED's, Buzzer etc.
I am attaching the Schematic Design.pdf
Thanks in advance!
KeithWalker
Joined Jul 10, 2017
3,615
REVIEW:
It would take me half a day to figure out what is connected to what and whether it is correct in your diagram, even if I knew what it was supposed to do. On its own, a diagram like that is more like a wiring list than a functional diagram. There is no information indicating the flow of data and control.
SUGGESTION:
The would convey much more information and be easier to comprehend if it was broken down into interconnected functional circuits like the attached:
Regards, Keith
hussainyakub
Joined Aug 3, 2017
8
Thanks @Keith for the reply.
I have already broken down my schematic into functional blocks. But, can you help me with review of USB to UART part as I am using CH340G for the first time.
Thanks.
KeithWalker
Joined Jul 10, 2017
3,615
Thanks.
I have not used the CH340G but if you have connected it correctly, the functionality will depend entirely on the bootloader you are using.
Keith
Picbuster
Joined Dec 2, 2013
1,062
Thanks in advance!
It looks ok
advice:
replace the diode (polarity protector) with a fet (lower resistance and dropout).
place ferrits in mpu power lines.
place filters in ref lines.
place an auto fuse in the USB power line.
Picbuster.
hussainyakub
Joined Aug 3, 2017
8
It looks ok
advice:
Picbuster.
Thanks @Picbuster for the advice. Can you please tell me the purpose for placing a fuse or polyfuse on USB power lines?.
