Sawtooth Generator Question
Kim Sleep
Joined Nov 6, 2014
435
Have a simple sawtooth generator, that works ok, but the variable resistor(RV1) does nothing.
As well, can I vary the frequency of the output?
Thanks in advance
38,871
The LTspice sim works fine (below):
Output shown for a pot wiper setting of 0% (green trace), 50% (yellow trace), and 100% (red trace).
Note that the output cannot drive any significant load, so an output buffer would be needed for that.
ericgibbs
Joined Jan 29, 2010
21,601
Hi Kim.
This is another option.
Shows Pot at 10% and 90%.
E
Update: Image #2.
By adding R1 [ which could be a variable resistor] it is possible to adjust On/Off periods of the output pulse.
Kim Sleep
Joined Nov 6, 2014
435
Hi Kim.
E
Update: Image #2.
View attachment 318255View attachment 318258
Thank you very much for your valuable help. I will be rebuilding another according to your updated schematics. Does it matter if I am using a 7555 for lower running operation??
Kim Sleep
Joined Nov 6, 2014
435
