Save and play Audio
mak99
Joined Sep 14, 2020
21
Hello. I am making a project where i want to save and play a 10 second long audio file when a button is pressed. I am looking for the easiest and cheapest way to make a small device that is able to do that. Right now i have bought a microcontroller(pic10f200) and a cheap speaker, as well as a breadboard(and the other things needed). I am not sure if this is the easiest way, as my project only need to do the things explained. So the question is if there is a easier way than a microcontroller or if i am on the right path. A cheap solution is key, as i am going to make 100 of them
peterdeco
Joined Oct 8, 2019
484
If you are intent upon building one from scratch, look at the ISD devices from Winbond. Many are stand-alone and don't need a microcontroller such as the ISD1620.
mak99
Joined Sep 14, 2020
21
mak99
Joined Sep 14, 2020
21
Okay, did not know that as i am new in this subject. I will research about and thank you for the response
ericgibbs
Joined Jan 29, 2010
21,567
hi mak
You can store upto about 10 secs of sound and replay.
There are jumper links on the pcb which can be set to play the sound at power Up or when a button is pressed.
Continuous or Single replay of message.
Also you can use it as a simple audio amplifier.
I use them on my home security system.
E
Clip:
Board ISD1820 chip
Onboard microphone, you can direct recording
About 10 seconds voice recording
High-quality, natural voice Restore can be used as a loudspeaker module
With a loop playback, jog playback, single-pass playback
The chip pin leads, through the microcontroller to control operation
Working voltage: 3 ~ 5V
Board size:54 x 38 mm
Ian Rogers
Joined Dec 12, 2012
1,136
If you need a LOOOONG sound... I use the WTV020M01 you load the sound onto it (SD) and place a button on pin 9 and it plays the sound... I bought 2 Both run of a tiny lipo and sound really good... DOWNSIDE... you need to convert to their format.. but again quite easy todo..
mak99
Joined Sep 14, 2020
21
Thank you for responding, i am not sure that is what i need at the moment, but defiently nice to know :)
mak99
Joined Sep 14, 2020
21
hi mak
E
Clip:
Board ISD1820 chip
Seems like exactly what i am looking for, thank you. Lets say that i wanted it to be triggered by a sensor/laser or something like that. do you have any tips regarding that
