No It is not a directional antenna....Answer depends if the satellite has a highly directional antenna or not. If directional, it points to the earth at approximately right angles to the earth surface. Thus, at the extremes of your red area, the antenna would be pointing somewhat away from you, making signals very weak.
Satellites can be placed tens of thousands of miles away from earth. Geostationary satellites are about 22,300 miles away (almost 36,000km). Others like the James Webb telescope is even farther away (1.5 million km). Not sure if that still counts as a "satellite" in general terms however, it is more like a "space object". The Webb telescope actually orbits the sun just like earth does, so it could be considered a satellite of the sun, not an earth satellite
| Thread starter | Similar threads | Forum | Replies | Date |
| A | River Level Monitoring Node_LoraWAN | Microcontrollers | 2 | |
Anyone familiar with LoRaWAN | Wireless & RF Design | 5 | |
| A | Using Nucleo-f411re with LoRa ra2 sx1278 | Microcontrollers | 0 |
