Creating a satellite tv system personally
Edwin95
Joined Sep 7, 2024
13
I had dish network satellite TV on August 30 2002 and changed it's wiring diagram in January 2004. In August 2002 or January 2004 I got shocked from trying to disconnect an f81 connector and the equipment wasn't damaged which was awesome. the equipment is 3x dp301 receiver, 1x dp34 switch, 1x quad lnb and 1x single lnb. I don't have the equipment anymore and I wanted to create a satellite TV system personally like this equipment but better because it's obsolete and will have cool protection for thieves.
Edwin95
Joined Sep 7, 2024
13
I mean how do you increase rg6 voltage and amperes on a dish equipment without damaging it. Is dishpvr 501 front end input gives more voltage and amperes than dishpro 301 front end input?
You don't. It's standard lnb operation voltages using DiSEqC protocol for the dp switch on both receivers.
The lnb might have a built-in DiSEqC switch or use old school voltage shift polarity switching.
https://www.google.com/url?sa=t&sou...UQFnoECCAQAQ&usg=AOvVaw3M2dVvrEpd-q--hYFYacKJ
My FTA dish on a HH motor.
https://forum.allaboutcircuits.com/threads/super-moon-shine.100322/post-900065
Switching matrix mess for hacking FTA
Ya’akov
Joined Jan 27, 2019
10,367
Welcome to AAC.
It appears that your question (which is hard to parse) is "how do I create a system that will cause a thief to get a bad electric shock if they disconnect the cables while trying to steal it?"
If this is what you are after, it is in direct violation of AAC rules. Discussions of devices intended to cause non-therapeutic or potentially harmful electric shock to a person or animal are prohibited.
If this is not your intention, please let me know immediately—otherwise, this thread will be closed to further replies.
Thank you for your cooperation, and please don't take this personally or imagine that your participation here is not welcome. This is just a matter of the rules which are in place for a reason.
[MODERATION]
Edwin95
Joined Sep 7, 2024
13
Welcome to AAC.
[MODERATION]
Sorry here is my real honest answer is how do you look up an old dish network serial number to find the bill of materials and verify the ownership is mine to make a professional self investigation of what caused a shock injury from trying to disconnect a f81 connector besides improper grounding and in line amplifiers. I also have experienced a dish network customer service misconduct.
