How to create a Satellite TV system after knowing it's components
Edwin95
Joined Sep 7, 2024
13
How do I get started on how to create a satellite TV system after knowing that integrated circuit chip is the brain and the lnb pcb board itself is the satellite signal receiving. I'm a visual learner and I don't know what physical materials are being used for programming the ic chips and the lnb pcb board.
Papabravo
Joined Feb 24, 2006
22,110
In particular, how do you imagine you could decrypt an encoded signal to recreate the origina images? It is not as simple as building a receiver, although for the frequencies used that would still be a challenge.
