Sanity/Knowledge Check - Vehicle Intercom System Design
sghioto
Joined Dec 31, 2017
8,758
That arrangement posted is how I would do it and recommend.
The output from the pot would connect directly to pin3 of the LM380.
The pots will allow the users to adjust there volume independently without affecting the other.
Tangence
Joined Oct 8, 2022
10
Is this because (almost) no current flows into the input of the op-amps?
Thanks in advance. This is a helping a lot.
sghioto
Joined Dec 31, 2017
8,758
If you mean that the pot can be connected directly to the LM380 correct.
That chip is designed for this type of configuration.
