Hi there i have a led panel with 2 parallel streams of 5 leds in series each.
When i am using the led driver / dimmer that was originally with the specific led panel from a 7,4 battey it gives 15,5 volts to the leds that under this voltage draw 0,85 A.
Bypassing the driver and using a bench power supply @ 15.5 v directly to the leds, the current draw does not exceed 0.61A while even if i increas to 16,5V the current does not increase over 0.7A (the power supply can give up to 5 Amps)
What i am not understanding?
