safety issue with sensor?
clangray
Joined Nov 4, 2018
261
I have a sensor that I have on a tiny breadboard 4 x 4. Its an IR, passes 100ma, works great. I want to mount it with 2 sided sticky tape on metallic-like frame. Its connected with Arduino cable a couple of feet from the base breadboard. Then it hit me, the bottom of the tiny breadboard seems somewhat exposed - do I need a layer of insulation tape (2 sided sticky) that insulates or maybe I need to put it in a enclosure? Ideally would like to leave it as is and mount it, but am concerned about bottom of sensor mock-up and 100ma.
https://www.adafruit.com/product/2463?gclid=EAIaIQobChMI3MPIkt_Z3wIVRLjACh2d0AM7EAQYAiABEgLFtPD_BwE
Hymie
Joined Mar 30, 2018
1,347
With the voltages present on the PCB, there is no safety hazard with regards you touching any part of the circuit – hence an enclosure protecting against accidental contact (for safety purposes) is not required.
However it is entirely possible that some conductive object/surface may contact the PCB, causing the circuit to malfunction and/or component damage – therefore some form of protection should be considered. An enclosure may be more aesthetically pleasing versus a layer of PVC insulation tape.
clangray
Joined Nov 4, 2018
261
This photo seems to indicate that the breadboard is backed with 2 sided sticky material. This is reassuring that my intentions are pretty much the same with the small breadboard:
