Run 2 x 110v fans from 220v supply ?
MaxHeadRoom
Joined Jul 18, 2013
30,818
If simple shaded pole motor and identical, you most likely will get away with it, but not ideal.
Many have a thermal cut out in the winding should overheating occur.
Max.
Damian S.
Joined Jun 5, 2017
It depends on the design of the fans and how their circuit works so this cannot be answered. In general I wold not recommend doing that. Get proper fans or a proper converter.
#12
Joined Nov 30, 2010
18,224
I would try it...if the fans were cheap and I didn't mind learning a new lesson.
After all, what is two fans on opposite voltage circuit breakers in a house, except the center is wired to zero volts?
Adding that center wire would remove all doubts.
WBahn
Joined Mar 31, 2012
33,239
Could I wire two identical 110v fans in series and power them from 220v supply ?
Thanks for any help.
Possibly, but if the loads on the two fans were not the same, then they will not divide the voltage equally. Also, consider what happens if one of them stalls for some reason.
tcmtech
Joined Nov 4, 2013
2,867
Yes it works. I have done it before. It works well until one stalls for any reason then after that the unstalled one either overheats and shuts down for over voltage or it burns up from it.
ian field
Joined Oct 27, 2012
6,536
There could be unequal voltage sharing - maybe you get away with it, maybe not.
Some split reservoir (voltage doubling) SMPSUs have 150V MOVs across each capacitor - there's only the fuse if they activate, and sometimes they do! You could check the data sheet for the max allowable motor voltage and select MOVs to stop it going higher than that - the 2 in series should be pretty safe.
codepuncher
Joined Jun 4, 2017
26
The 2 prong connections on the motors are not marked for polarity so I guess it`s not important ? seems odd.
Thanks for your efforts Max
tcmtech
Joined Nov 4, 2013
2,867
I have a pair of high powered 12 DC fans from a large commercial server cooling system I run in series off of a 15 volt DC power pack that have been in service for air circulation under my house most of the year. They work fine that way.
Startup is always a bit odd though. One will spool up to near full speed then the other one will take off then they balance out.
