RS232 with Arduino
ChangeIsConstant
Joined Mar 26, 2015
16
The code is -
Code:
void setup() {
  // put your setup code here, to run once:
Serial.begin(9600,SERIAL_8N2);
pinMode(0,INPUT);
void loop() {
  // put your main code here, to run repeatedly:
while (Serial.available()) {
  Serial.println(Serial.read(),HEX);
ChangeIsConstant
Joined Mar 26, 2015
16
When the input is connected to pin 0, I get the following errors while uploading the code -
Code:
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x01
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
35,145
You have to backup. We cannot see what you are doing.
Do you have a digital camera? Show us a sharp well focused photograph of the cable from the scale to the first circuit that it is connected to.
ChangeIsConstant
Joined Mar 26, 2015
16
I am attaching 2 images (sadly taken only from my mobile phone since that is the only thing available) of the circuit - the cable, MAX232 to arduino.
35,145
There should be a capacitor +ve lead connected to pin-2. Is the -ve lead connected to GND?
You show a 5th capacitor. Where are its leads connected?
