Actually pushing the snow to the side would probably be the most common method. Easily much more efficient too considering that a worm gear could even be used to push things along (albeit at a snail's pace). A super low-powered blower on the other hand would be practically useless. For that more generous amounts of power are needed. The latter is also rather noisy and obtrusive by the way being somewhat difficult to control the exact direction of the spray of snow and such.Why are you using a snow shovel? The most common way of mechanized snow removal for walkways and such is a snow blower, and that's done because shoveling is just too hard and not as efficient.
On streets or parking lots I agree, but I don't think that's what he was talking about. Residential snow removal at least in my area is done by either shovel or blower. And an automated snow shovel would be a very hard to do thing.Actually pushing the snow to the side would probably be the most common method.
It certainly wouldn't be the most trivial project. (Unless the TS just happens to be some kind of amazing genius or what have you.)On streets or parking lots I agree, but I don't think that's what he was talking about. Residential snow removal at least in my area is done by either shovel or blower. And an automated snow shovel would be a very hard to do thing.
Well I guess that settles THAT question...would a petrol flame gun as used in garden weed control be of use,
could be great fun to put that into a robot,
but just wondered what sort of amount of heat is needed
( assuming salt put down afterwards can keep the water from freezing )
Has anyone with lots of snow tried a weed killer flame gun ?It certainly wouldn't be the most trivial project. (Unless the TS just happens to be some kind of amazing genius or what have you.)
Again I'll will be called crude and unkind, but, you must not have lived where there is much snow. What do you consider a lot of snow? Flame heat is going to cost a lot of money and do a very bad job of clearing snow, then you have the water leftover from that snow melt. Not a good idea at all.Has anyone with lots of snow tried a weed killer flame gun ?
I'm interested,
@shortbusAgain I'll will be called crude and unkind, but, you must not have lived where there is much snow. What do you consider a lot of snow? Flame heat is going to cost a lot of money and do a very bad job of clearing snow, then you have the water leftover from that snow melt. Not a good idea at all.
Where I live we don't consider that much snow a worry. I don't even bother to clean the sidewalk for that small amount.Where I live, if there is more than a few cm of snow, a national emergency is called.
I agree. If I need to clear that little, a shop broom would finish the job without the “batteries” dying. Carrying enough salt to prevent the water from freezing, would add 20 lbs for every 100’ of walkway, requiring more powerful motors requiring heavy batteries. And the salt would destroy concrete walkways.Where I live we don't consider that much snow a worry. I don't even bother to clean the sidewalk for that small amount.
Thank youI agree. If I need to clear that little, a shop broom would finish the job without the “batteries” dying. Carrying enough salt to prevent the water from freezing, would add 20 lbs for every 100’ of walkway, requiring more powerful motors requiring heavy batteries. And the salt would destroy concrete walkways.
All in all, sounds impractical… or very very difficult to engineer .
My guess: the same people who bathe in Borax.Has anyone with lots of snow tried a weed killer flame gun ?
No, you have not.I have made up a robot frame with 2 motors to shovel snow.
Let’s see, my moderate sized snowblower uses a 6HP gas engine. The equivalent of 4500 W. Maybe your 100W of power could shovel the driveway for a doll house.Battery: 20 AH 12V
Motors 2X50W
