All,
I play around with broken TVs, Monitors and the alike on occasion and recently I found a small LED TV that appears to have a back light issue of some kind. Originally this TV was used for my young kids monitor.
Upon further investigation I found a ribbon cable leading to the back panel lights connector. The connector is more like the type you push in the ribbon and place a small tape over the top to hold in place type. To remove the cable there was a pull tag (blue). It does not have a clamp down like IPADs etc.
Anyways this TV appears to have corroded at the connector to the point that it arc'd/corroded/turned green over time at the connection. I cleaned the panel connector up with Electrical connector cleaner and a soft brush. The panel connector appears clean now but the ribbon suffered extensive damage from the arcing/corrosion at the connection points.
I went looking for an exact replacement. The model and make of the TV (RCA Led24a45rq) appears to must have had more than a single type of connection for the back panels as I found a replacement back light cable but it has solid connectors.
Is there a way to clean or reuse this very thin cable (Its not the type you score with a knife and pull insulator off)?
For example could I cut off the bad, tape off area prior to the new connection location point on the ribbon, and sand things lightly with fine sandpaper to get a good connection?
Or is there a place to by ribbon cable by the foot (pre-stripped)?
Thanks for all the help,
Chris
Chris
