Ribbon Cable Extender Help Needed
Caludaj
Joined Jan 5, 2025
48
Hey guys.... I am in need of an extension cable/double female connector that will extend an 8-Pin Flat Ribbon Connector a couple of inches.
Please see the attached photos for the exact kind of cable I am using. This cable connects a Video Screen to a circuit board.
Thanks in advance for the help!
Joe
sparky 1
Joined Nov 3, 2018
1,218
2 of these can be soldered back to back (measure all dimensions and space requirements) clean with isopropyl and neatly apply white silicon sealer over the solder joints then insert a flat flex extender to the connector assembly. Assembly reference image below of 4 pin but 8 pin is available.
68610814122 Datasheet WR-FPC SMT ZIF Horizontal
