Ribbon cable connector
Hornnumb2
Joined Jan 17, 2013
31
What do I need to measure to figure out what connector i need to order? Of course count the pins but do I measure the overall length. The flip locking tab broke off. Thanks Michael
nathook
Joined Jan 30, 2019
5
The connector is of type 'FFC' or 'FPC'. There are various specifications to measure, pin count, pin pitch, top or bottom contacts, contact depth/length (measured on the flexible printed circuit 'plug'). You'll probably have to look for visually similar FPC parts, then compare the drawings on the datasheet with your own measurements to confirm.
