Ribbon Cable and Printed Circuit Connection
dporay
Joined Oct 10, 2015
18
In the attached drawing the ribbon cable going to the display has been disconnected from the printed circuit traces. There is no evidence of solder which has secured the cable to the traces. The only evidence of an electrical connection between the cable and the traces is a black carbon-like film on the end of the cable. How is the cable secured to the pc traces?
35,319
Your photograph is out of focus and difficult to see clearly.
LCDs are often manufactured on glass and use a carbon film connector called zebra elastomeric connector.
Physical pressure is what holds the connection in place.
dporay
Joined Oct 10, 2015
18
Thanks for the reply. Sorry for the unclear picture. Can a new coating of the carbon film be applied since the existing film has no more adhesion properties? If so, where can this coating be obtained?
35,319
ZEBRA elastomeric connectors require no adhesive. It is kept in place by sandwiching it in between the LCD and PCB.
Search for ZEBRA elastomeric connector.
LesJones
Joined Jan 8, 2017
4,544
You have not said if your connection uses the zebra type connection. You need to get someone with a better camera to take some pictures of your connection. Another guess is that it may be a monosotropic type of bonded connection. This uses heat and pressure to make the bond.
This is some information I found on the process.
This shows the connection that I repaired on a central heating thermostat.
There is some more information about how I carried out the repair here.
http://lesjhobbies.weebly.com/repairing-honeywell-cm901-display-fault.html
Les.
dporay
Joined Oct 10, 2015
18
Les.
This looks interesting. I will go to the link you supplied for more information.
