RGB torch code _ Help to add a long press function
Moxxie
Joined Mar 2, 2022
So I've been working on an RGB torch for a little while but I'm struggling to get over the last hurdle. The code I have written is working but I'd like to add a long press function to buttons 1 and 2 to change the colour quickly rather than having to cycle through all the brightness levels, I have tried many different things to get it to work but no such luck, any help would be appreciated.
Mod: placed Code into Code Tags
C-like:
#include <Pushbutton.h>
int count = 0;
#define button1 2
#define button2 3
#define button3 4
Pushbutton pbutton1(button1);
Pushbutton pbutton2(button2);
Pushbutton pbutton3(button3);
void setup() {
  pinMode (5, OUTPUT);
  pinMode (6, OUTPUT);
  pinMode (9, OUTPUT);
void loop() {
  digitalWrite (5,LOW);
  digitalWrite (6,LOW);
  digitalWrite (9,LOW);
    if (pbutton1.isPressed()){
      count = count + 1;                // Button 1 increments the program forwards
      delay(100);
    if (pbutton2.isPressed()){
      count = count - 1;                // Button 2 increments the program backwards
      delay(100);
    if (pbutton3.isPressed()){
      count = count = 0;                // Button 3 resets the program back to the start
      delay(100);
if (count == -1){
  count = 13;
  delay (100);
if (count == 0) {
  delay (100);
//Red:
if (count == 1){
analogWrite (5, 63);
delay (100);
if (count == 2){
analogWrite (5, 126);
delay (100);
if (count == 3){
analogWrite (5, 189);
digitalWrite (6, LOW);
digitalWrite (9, LOW);
delay (100);
if (count == 4){
analogWrite (5, 255);
delay (100);
//Green:
if (count == 5){
analogWrite (6, 63);
delay (100);
if (count == 6){
analogWrite (6, 126);
delay (100);
if (count == 7){
analogWrite (6, 189);
delay (100);
if (count == 8){
analogWrite (6, 255);
delay (100);
//Blue:
if (count == 9){
analogWrite (9, 63);
delay (100);
if (count == 10){
analogWrite (9, 126);
delay (100);
if (count == 11){
analogWrite (9, 189);
delay (100);
if (count == 12){
analogWrite (9, 255);
delay (100);
//White:
if (count == 13){
digitalWrite (5, HIGH);
digitalWrite (6, HIGH);
digitalWrite (9, HIGH);
delay (100);
if (count == 14){
  count = 0;
  delay (100);
Thanks, Mox.
Marc Sugrue
Joined Jan 19, 2018
222
C-like:
int count = 0;
#define button1 2
#define button2 3
#define button3 4
void setup() {
void loop() {
      delay(100);
      delay(100);
      delay(100);
if (count == -1){
  count = 13;
  delay (100);
if (count == 0) {
  delay (100);
//Red:
if (count == 1){
delay (100);
if (count == 2){
delay (100);
if (count == 3){
delay (100);
if (count == 4){
delay (100);
//Green:
if (count == 5){
delay (100);
if (count == 6){
delay (100);
if (count == 7){
delay (100);
if (count == 8){
delay (100);
//Blue:
if (count == 9){
delay (100);
if (count == 10){
delay (100);
if (count == 11){
delay (100);
if (count == 12){
delay (100);
//White:
if (count == 13){
delay (100);
if (count == 14){
  count = 0;
  delay (100);
Thanks, Mox.
Try implementing a MOVING AVERAGE FILTER where a speed variable will increase the longer you hold the button. Think of it as a shift register where you populate the data at regular intervals and calulate the average of the variables. Old values will drop off the filter and new ones get added. Start with something like 10 variables which update every 0.5 seconds as a start, speed will then increment every 0.5s until it reaches your max rate. As soon as the button is released then clear the filter elements for next time.
click_here
Joined Sep 22, 2020
544
+1 for the finite state machine
But keeping with your code you can do something like this..
Code:
if(b1 && b2)
else if(b1)
else if(b2)
else if(b3)
