RF LC oscillator question
Yabba Rays
Joined Oct 5, 2016
37
I've seen some Hartley oscillators both with and without the R/C combination in the feedback loop. What is their theoretical purpose? I've tried both with and without the inserted R/C combo with around those values, but can't determine any worthwhile differences. The frequency is around 1 MHz and Vcc for Q1 is 9 volts. The output is into an NPN B-E junction. What might the R/C components do?
Thank you.
Papabravo
Joined Feb 24, 2006
22,111
Thank you.
The Barkhausen condition is a necessary condition for oscillation. It has two parts a gain part and a phase shift part. It is not a sufficient condition for oscillation. Most oscillators need some additional factors to start like initial conditions, noise, or other deviations of components from ideality.
https://en.wikipedia.org/wiki/Barkhausen_stability_criterion
Yabba Rays
Joined Oct 5, 2016
37
Yes, indeed... but what do the 270 ohm and 10 nF capacitor do? It operates equally well (as far as I can tell) without these components.
