Hello, my substrate is FR4 1.6mm and signal thickness is 1oZ (0.035mm)
the width of a trace is about 0.2mm also there will be copper pour around the trace with 0.2 spacing from the trace
I have found connector shown in the link below.
but i am not sure if would be able to solder this connector to the PCB.
from the data sheet bellow they say that the distance between pins is 2'A'
A=1.73mm which is 2*1.72 much higher then 1.6mm.
How do i find a connector which could fit my 1.6mm and trace 1oZ thichness?
they is no such category in digikey filter,so how could i know is this connector whould fit my PCB?
https://www.digikey.com/en/products/detail/cinch-connectivity-solutions-johnson/142-0711-821/396572
