RF amplifier and Power amplifier
samrat
Joined Apr 2, 2008
30
Good-day,
For our major project, my group wants to boost up the existing power that the school radio is running on from 4 watts to 50 watts. The radio station is using a 3 element FM radio omni antenna(dipole) with impedance of 50 ohms. My understanding is that we will have to design a separate rf amp and a separate power amp that is turnable(0-50)..The current station is operating on an exciter only..
I am just asking for any handy tips while designing the circuit...Some handy reference would be great...:confused:..
beenthere
Joined Apr 20, 2004
15,819
The ARRL site should be a good source for RF amps. They are a bit of a challenge for a first-time project, though. You might also Google for "linear amplifiers" to see if you can turn up something there.
You might wish also to check your station license to make sure the power boost is legal. The regulating authorities can be very nasty to have to deal with if they think you're not obeying the rules.
SgtWookie
Joined Jul 17, 2007
22,230
I second Beenthere's recommendations - but I feel that the 2nd part needs a lot more emphasis.
You must be absolutely certain that the station is operated in strict compliance with the license granted by the FCC. They don't generally give warnings. They'll seize equipment, slap heavy fines on the operators of the station, and it will practically take an act of Congress to reverse the damage.
It is the station operator's responsibility to ensure compliance. "I didn't know" will NOT be an acceptable defense.
JoeJester
Joined Apr 26, 2005
4,390
TITLE 47--TELECOMMUNICATION
COMMISSION (CONTINUED)
PART 73_RADIO BROADCAST SERVICES--Table of Contents
Subpart C_Noncommercial Educational FM Broadcast Stations
Sec. 73.506 Classes of noncommercial educational FM stations and channels.
(a) Noncommercial educational stations operating on the channels
specified in Sec. 73.501 are divided into the following classes:
(1) A Class D educational station is one operating with no more than
10 watts transmitter power output.
(2) A Class D educational (secondary) station is one operating with
no more than 10 watts transmitter power output in accordance with the
terms of Sec. 73.512 or which has elected to follow these requirements
before they become applicable under the terms of Sec. 73.512.
(3) Noncommercial educational FM (NCE-FM) stations with more than 10
watts transmitter power output are classified as Class A, B1, B, C3, C2,
C1, or C depending on the station's effective radiated power and antenna
height above average terrain, and on the zone in which the station's
transmitter is located, on the same basis as set forth in Sec. Sec.
73.210 and 73.211 for commercial stations.
(b) Any noncommercial educational station except Class D may be
assigned to any of the channels listed in Sec. 73.501. Class D
noncommercial educational FM stations applied for or authorized prior to
June 1, 1980, may continue to
[[Page 153]]
operate on their authorized channels subject to the provisions of Sec.
73.512.
[43 FR 39715, Sept. 6, 1978, as amended at 49 FR 10264, Mar. 20, 1984;
52 FR 47569, Dec. 15, 1987; 54 FR 16367, Apr. 24, 1989; 54 FR 19374, May
5, 1989]
Transmitting more than 10 watts into your antenna would put you in violation of 47 USC 73.506, assuming your a Class D station, and places your school's license in jeopardy. If your transmitting 4 watts and your license allows you 10 watts, then you can build a smaller amplifier to satisfy the requirements of your license. You will have to ensure the amplifier meets FCC compliance before placing it in service at your station.
Ensure you understand the ramifications of 47 USC 73 as it applies to your school's license. What does the Chief Operator at the station say?
If your not in the U.S., I'm sure your country has a regulating agency like our FCC, following similiar legislated rules. Check with your regulating authority.
Ignorance of the law is not a plausible defense.
Gadget
Joined Jan 10, 2006
614
Is that 10 watts or 10 watts EIRP as is the norm. If so, then that 4 watt transmitter/3 element yagi combo is probably already at the limit..... (even with cable losses)
samrat
Joined Apr 2, 2008
30
Thanks for the infor guys. I live in fiji (in the South Pacific)and I am quite sure that the licence granted to the school allows it to operate on 50 watts. This is a challenge for us but with help from you guys, we will complete this in due time. By the way, I will check again with the authorities on Monday just to confirm where we stand. Will keep you guys informed with our progress and will ask for help in any difficulties arise.
Thanx again..SR
SgtWookie
Joined Jul 17, 2007
22,230
You can use a Class C amplifier if your antennna (load) is tuned to your allocated transmit frequency, and filter(s) are used to reduce sideband and harmonic emissions to within the limits allowed by the station license.
Good quality high-power RF filters are not cheap.
bertus
Joined Apr 5, 2008
22,931
I like to know about the frequency of your transmitter.
Most amplifiers found on the internet are made by HAM radio amateurs.
They are working at specific frequencies, like 160 Meters , 80 meters , 40 meters, 20 meters , 15 meters , 10 meters , 6 meters , 2 meters , 70 centimters , 23 centimeters, 13 centimeters.
See the link to an radioamateur with lots of schematics links and drawings.
http://www.ac6v.com/
Greetings,
samrat
Joined Apr 2, 2008
30
The frequency of our radio is 89.6MHz with max deviation of 75kHz.The range of broadcasting is not so important in my country because I have had a look at the laws and as long as we stick with th 50watts out put from power amp, we are ok. So any suggestions how to calculate the gain around the transistor or mosfet would be great.I mean, no exact values but just a dummy diagram and how to calculate the exact component values from the diagram would be awesome...we are stuck now in trying to ensure that our calculations are fool prove. Please a step by step guidance is highly appreciated.
JoeJester
Joined Apr 26, 2005
4,390
Two ways to increase the "effective power" of a broadcast station ... add a power amplifier or use a higher gain antenna. Your country doesn't specify using the "effective power" from the antenna ... called EIRP?
You would need an 11 dB amplifier to go from 4 to 50 W.
What is the model of your transmitter, the transmission line, and what is the model of your antenna?
Can you provide the link to your regulating agency's information?
