Schematic attached is found in the datasheet of the IC RV4145A. It's a low power controller for AC outlet ground fault interrupters. They have two versions of the schematic, a two-wire configuration, and a three wire configuration. The picture attached is the three wire version which has an extra current transformer. The two-wire version only has a transformer and it's not designed to detect grounded neutral faults. I'm trying to study the schematic, and this is my question:
Does the bridge rectifier have two purposes here? Supply the IC and close the path through the SCR for the solenoid. Is it right?
