Review Request - CD4017BE and NE555P based LED Chaser
radi8
Joined Oct 18, 2024
24
Not necessarily....there are high intensity, low current LEDs.
I may not have been looking very hard, but the brightest colored LEDs I've found for 2mA are about 80-90mcd (not to mention that there aren't symbols for any of them in my design software), and I preferably want higher. The LEDs I've been looking at do have a diffuser.
250ms? is that between flashes?
Be aware that if you choose 3V supply, then a NE555 won't work. You'll have to use a CMOS timer.
250ms between flashes, yes.
My current design has 2 3v CR2032s (in series for 6V), and I am using an LMC555 rather than an NE555.
eetech00
Joined Jun 8, 2013
4,746
Don't let your design software drive your design.:)
But does the whole "tree" have a diffused, or clear, cover?
Ok....then 250ms is the period, so frequency is 1/0.250 = 4 Hz
If we assume (I hate that word) that 2 LEDs, at 10mA each, will be on while the tree is on, then the (2)CR2032 batteries will be completely drained in about 12.5 hours of constant use, and the "tree" will probably be unusable before then.
radi8
Joined Oct 18, 2024
24
Good point.
Diffused. Here's an example of one
Correct. It's supposed to switch the LED every quarter of a second.
I found some LEDs that I'll use that are 2mA. They aren't the brightest, unfortunately, but they'll make do. It isn't really meant to be an "on all the time" sort of device, I guess? It's still a good point, though.
eetech00
Joined Jun 8, 2013
4,746
2 LEDs, at 2mA each, will be on while the tree is on, then the (2)CR2032 batteries will be completely drained in about 125 hours of constant use.
38,926
For longer battery life you can use a larger coin-cell such as the CR2450 which has about three times the capacity of the CR2032.
radi8
Joined Oct 18, 2024
24
This is my latest schematic. Does it look how it should? I switched to the 2 CR2450's, and a different set of LEDs which are now 2mA. I ended up making symbols for them because they weren't in the library I had. I'm glad I figured out how to, though. They are just clear (but colored) LEDs, no longer diffused ones.
eetech00
Joined Jun 8, 2013
4,746
If you really want the LEDs to switch every 1/4 second (on for 1/8 second), then, if C1=1uF, R1 should be ~180k = 4Hz, not 3Mhz.
For a supply of 6v, LED resistor should be about 1.5k-1.6k for 2.65v@2mA, but you'll probably need to adjust.
radi8
Joined Oct 18, 2024
24
I'm not exactly sure why the schematic says 3Mhz, whoever made the symbol for my software put that. I'm wanting it to switch every 1/4 sec, but also be high for that whole time.. not 1/8th.
eetech00
Joined Jun 8, 2013
4,746
Ok, that's different then what you wrote earlier. Then the period is actually 1/2 second (for 50% duty cycle, on/off for 1/4 second each), so the frequency now becomes 1/0.5 = 2Hz, so R1 should be about 360k.
