Reverse engineering a membrane keypad
jsw2000
Joined Nov 10, 2023
I have a machine which have 2 BLDC motors and I need to control it. I'm planning to control the motors by tapping the membrane keypad which already exists in the machine using microcontroller signal. I found the 2 pins that connected to certain button and when I keep pressing the button and checking the continuity, multimeter didn't give a beep sound. When I checked the voltage difference in each pin when I pressed the membrane button one was giving 14V while other pin having 4V. But these voltages didn't fluctuate when I pressed the button, but the button function keeps working which means the button membrane should be working fine. Is there a way to mimic the button press using a microcontroller or I need to know an alternative way to control 2 BLDC motors which are 12V and 15A rated current.
MaxHeadRoom
Joined Jul 18, 2013
30,809
What is the type of controller you have?
What are the machine details?
Is this an OEM or a DIY project?
Are you actually switching motor power with the buttons?
IMO, most membrane PB's have no place on a motor controlled machine.
jsw2000
Joined Nov 10, 2023
I'm doing this for my university project, and this is an existing product on the market. I'm using Nucleo F401RE and this is a bowling machine for cricket.
