I am using 2 CR8401-1000-A current transformers in opposite polarity to sense current on either side of a load. The Idea is that when the load is not in failure mode that the sensed current waveforms will be exact opposites and when "added together" will cancel each other out. In failure mode, or ground fault, there will be an alternate path for current. The wave currents will no longer cancel and yield a net current. This signal is amplified by an op amp circuit, and rectified by a precision full wave rectifier. The now DC signal is sent to an ADC. A micro controller coupled to the ADC will throw a breaker at programmed current thresholds. My question is this, can the 2 current transformers be connected in reverse polarity in parallel directly, or should there be a buffer circuit between them?
