I was fixing to hack and integrate one of these switches into a little lamp I'm hoping to sell. I need RoHS paperwork which is pretty much impossible to get - the switches are made in China and they're quite ubiquitous but it's almost impossible to track down a manufacturer - not even via the sellers. Sure, the switch comes marked with CE and RoHS on the cover, but it's the paperwork that's the important bit. Quite annoying as in its current application the switch works brilliantly.
So I'm thinking of making my own version using components I can source that have relevant documentation but the main problem being that I'm an electronics dunce. The switch works like this:
Any open source circuits out there that you can point me in the direction of so I can start having a play..?
- Works on 12-24VDC max 3A
- Touch once - on/off
- Continuous touch - fades up/down alternately
- Switch remembers on/off and brightness level states when power is removed
