Reverse Clipping (peak-detecting) circuit
stepank
Joined Apr 19, 2018
8
Hello AAC -
I am trying to design a circuit that takes a waveform and only leaves the peak, with some variability of how much of the peak is passed. Not exactly a clipping circuit, not exactly a peak detector.
This is the closest I could get: http://tinyurl.com/y7rbzxt7
But it's not ideal for a variety of reasons. The incoming waveform is 10v, the potentiometer has a range of 0-12v - so I'm not sure why I can't get to a resolution that totally nulls the incoming waveform. I'm also using a buffer for the variable voltage threshold - because I can't seem to get it to work any other way - but I feel like there should be a way around that, right?
Can anyone help set me on the right path?
danadak
Joined Mar 10, 2018
4,057
Some confusion, do you want to "gate" a portion, in time, of the waveform
at its peak ? Like +/- 1 uS around the peak value ?
Is waveform periodic ? If so freq range needed to evaluate.
Regards, Dana.
38,729
Here's the circuit modified to do what (I think) you want.
The output is shown for several different pot clip-point settings
I also had to add a buffer to the pot output to avoid degrading the signal accuracy.
stepank
Joined Apr 19, 2018
8
Thanks for the responses, let me try to communicate it a little clearer, though - because I think I didn't make it apparent.
The frequency range would be 20-20k, roughly.. and it would operate as a gate, insomuch as everything below the threshold would be 0v...
Crutschow's circuit works really well, but I'd like it to operate with bipolar signals, ultimately - is there a way to get to a similar solution with +/-12v? I feel like I must be missing something simple..
