Sorry, correction:
Xl = jWL = j(2*∏*50*0.7) = 219.91j Ω
Previous post corrected!
Ok, thats correct, but why have you ignored the 'j' imaginary impedance in your Current calculation! and used only the Real part.???Sorry, correction:
Ok, thanks..hi,
Thats also correct.
The over voltage factor occurs at resonance, the reactive voltage across the Ind and Cap can be much higher than the voltage source, so the voltage Rating of the components should be able to withstand that voltage.
E
Hi,Ok, thanks..
3-
ω1 = 10%*ω = 440rad/s
Re-calculated all Xc, Xl, I, Vr, Vl and Vc but i'm skeptical.
Xc = -363.64jΩ
Xl = 440jΩ
Ztotal = 60-363.64j+440j = 60+76.36jΩ
I = 240|0º/60+76.36j = 2.47|-51.84ºA
Then:
Vr = 60*2.47|-51.84=148.2|-51.84º
Vl = 440j*2.47|-51.84=1086.8|38.16º
Vc = -363.64j*2.47|-51.84 = 898.19|218.16º
I'm skeptical because shouldn't the sum of these 3 voltage drops be equal to Vin=240V????
It's possible to define resonance for a parallel RLC circuit in 3 different ways:Sir Eric, there is something here I can't understand...
I have a circuit that has 2 branches.
The 1st branch has a resistor (RL) and an inductor (L).
The 2nd branch has a resistor(RC) and a capacitor (C).
Both branches are at a parallel setup.
L = 2mH
C = 80μF
Teacher asks us to calculate RL and RC so that the circuit is at Resonante Point for any frequency!
Regarding math, I can't figure out what this means... Can you give a hunch???
Edited;
My teacher says that if (RL)^2 = (RC)^2=L/C, then the circuit will be at Resonant Pint for any frequency... But I can't understand why...
Thanks for replying.It's possible to define resonance for a parallel RLC circuit in 3 different ways:
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/parres.html
You will get different frequencies for the 3 different definitions. To get the answer your teacher gave you, the 3rd definition must be used. The definition itself should give you a clue about what you need to calculate.
morning Psy,Thanks for replying.
It should, indeed give me a clue, but I cannot understand why (RL)^2 must be equal to (RC)^2. Is it a condition so that the circuit is a lossless circuit, meaning that it cannot have elements dissipating heat, and as inductance and capacitance cancel out themselves each other, this should be the only way to ensure that the circuit is lossless????
Hi Sir Eric...morning Psy,
Consider the Phase relationship of the Voltage and Current related to a Power Factor of unity.
Post your calc's and answers and we can check them out.
E
Did you get this frequency from spice?It's possibly worth noting that the maximum parallel impedance (an alternative measure of resonance) is obtained at 959.4 Hz.
Well, the condition we were said by the teacher to look for was when the imaginary part of the circuit impedance was equal to zero.Since the frequency of resonance is deemed (by the equation you used) to be when the source voltage and current are exactly in phase then this is the condition one would look to confirm. That is, at 722.15 Hz (correct), the source voltage and current are measured to be exactly in phase.
This condition is also interpreted as the frequency at which the parallel circuit is purely resistive in nature.
You have a lot of formulas there.Did you get this frequency from spice?
I gave a formula here:
http://forum.allaboutcircuits.com/showpost.php?p=675743&postcount=39
The formula gives 959.177 Hz
