Resonant Frequency
HARRYthefrog
Joined Apr 7, 2021
5
I need to find the resonant frequency of a RLC circuit but not sure if i have done it right or not :
so i did
Spec:
50mH
0.01uF
120R
1V dc
1/2pi sqrt 50mH*10^-3*0.01uF*10^-6=7118 Hz (is this right ) ?
LvW
Joined Jun 13, 2013
2,038
so i did
Spec:
50mH
0.01uF
120R
1V dc
How do you define "resonance"?
The result depends on the position of the resistor - in series to L or in parallel to L||C ?
HARRYthefrog
Joined Apr 7, 2021
5
i did it by putting everything in series ,the questions that i was given just said RLC so i just put it in series .
Ian0
Joined Aug 7, 2020
13,306
Does it make any difference? Isn't the resonant frequency the same regardless of the position of R and whether it is series or parallel resonance. It's the Q that changes.
LvW
Joined Jun 13, 2013
2,038
Yes - it makes a difference. When R is in series to L only (and not to the parallel combination L||C) the resonant point is not simply SQRT(1/LC). The dame applies when L in series to C with R||C.
Try to find the difference while simply applying the definition for resonance.
Ian0
Joined Aug 7, 2020
13,306
Yes - it makes a difference. When R is in series to L only (and not to the parallel combination L||C) the resonant point is not simply SQRT(1/LC). The same applies when L in series to C with R||C.
You're correct - I wasn't thinking of resonant circuits quite that advanced!
