[RESOLVED] My LCD doesn't show text. Arduino
filipmr
Joined Jan 2, 2021
64
I had a problem with a button once, it was hooked up correctly but it didnt work, the i tried putting the wire on the button and it worked, something was wrong in the breadboard , so maybe something similar is going on
35,207
I see the rectangles now, but they are kinda yellow, and I only see them in row 1
That is good. That is what you want.
Next, adjust the contrast pot so that you can make the rectangles fade and then dark again.
For code testing, you want the rectangles to appear between nothing and just visible.
filipmr
Joined Jan 2, 2021
64
i dont understand
AlbertHall
Joined Jun 4, 2014
12,653
Now while testing the code make sure that you continue to see those boxes.
If the LCD setup code works correctly you should then get two rows of boxes.
filipmr
Joined Jan 2, 2021
64
Thanks, Now i get text but instead of hello world, I get worldhello`vп&_F
_F b _fxello worl
