Umm... each resistor handles 1W, so both will be 2W.Originally posted by Azgard@Dec 16 2005, 04:16 PM
The series resistance will be 100 Ohms, but the resistors will still only be able to handle 1 watt, so no.
[post=12500]Quoted post[/post]
The answer is YES. Resistors in series or in parallel the wattage adds.Some ohms LAW PRACTICE would resolve this.Originally posted by n9352527@Dec 16 2005, 11:31 AM
P=I^2*R
I is the same because the total resistance is the same. With 50 ohm resistance the power is half the total power. So the total power dissipation is divided into two, half for each resistor.
[post=12502]Quoted post[/post]
Hi power is additive ,whether in series or in parallel,in paralell circuits the resistases do not matter providing each can carry its own load. in series circuits -2-50ohms 1watt=100ohms 2watts, however in acase of unequal resistances it becomes practically incorrect. say youwant 100 ohms 2 watts, while 2- 50ohms 1waattwould work, an 80 ohm 1watt and 20ohm 1 watt would not work the 20ohm would carryonly 20%of the power and the 80ohm would have to carry 80%-more than 50% and would burn.Originally posted by CoulombMagician@Jan 28 2006, 01:54 AM
Power is cumulative so long as they do not interfere with each others dissipation. Example 1, a surface mount resistor. You can solder one on top of another but together their power rating is not 2x that of one.
Example 2, a large wirewound adjustable power resistor with one of those metal slides on it for a wiper. If all the load current passes between the wiper and one terminal the power dissipation is concentrated in only a fraction of the length of the resistor and maximum power is that same fraction of the rated power of the whole resistor.
[post=13585]Quoted post[/post]
No...If you want an equivalent 100 ohm 2W resistor, put two 200ohm resistors in parallel. If you put them in series, as you've said, it would equate to a 1W resistor. For an example, if you put a 1W and a 10W in series, the wattage would equate to the smaller wattage of 1W.Originally posted by Propeller@Dec 16 2005, 01:59 AM
This might seem to be a stupid question.
I need a 100ohm 2W resistor.
Can add 2x 50ohm 1W resistors in series to acheive this?
[post=12491]Quoted post[/post]
I think i'm stuck in a loop. This topic would never ever end!!!Originally posted by stuzman@Jan 29 2006, 05:35 PM
[post=13629]Quoted post[/post]
I fully agree with the calculations of chesart I personally avoid long posts (keyboard challenged), and would think anyone can follow the presentation.Originally posted by chesart1@Jan 29 2006, 02:16 PM
Stuzman and Propeller,
My calculations shown in one my previous messages and repeated here for your conveneience prove that two 50 ohm 1 watt resistors could replace one 100 ohm 2 watt resistor:
Lets use an actual example to illustrate the point:
14.14 volts across a 100 ohm 2 watt resistor results in 2 watts dissipation.
Now lets substitute two 50 ohm resistors for the 100 ohm resistor and figure out the power dissipated by each resistor.
The curent is still .1414 amps.
So the power dissipated by each resistor is
P = .1414 amps * .1414 amps * 50 ohms
P = .02 * 50 = 1 watt
And this proves you can replace a 100 ohm 2 watt resistor with two 50 ohm 1 watt resistors in series.
The incorrect statement I referenced in my previous message was about resistance tolerance, not power.
Coulomb Magician,
I agree with you only with regard to the true power per the proof I provided in my calculations.
However, wire wound resistors also have a finite amount of inductance that affects AC operation. If you apply a sinusoidal waveform to the two wire wound resistors, you may be correct. However, if you apply any non-sinusoidal waveform with sharp rise times to the two wire wound resistors, then I am uncertain about your statement.
John
[post=13633]Quoted post[/post]
My point is really quite simple. The power rating of a resistor is based on how much heat can be removed under normal operating conditions such as the maximum operating temperature and given maximum ambient temperature, the transfer mechanism of heat out of the resistor such as still air convection, and the size of the physical package. That's why the rating of an 0805 resistor is the same whether it's 1k or 100k. If you solder one SMD on top of another the effective area for dissipating heat has not really increased very much so your trying to dissipate twice as much heat through about the same area. If the resistors are physically separated you have about twice the area and twice the power dissipation so about the same temperature rise and you're still within rating.Originally posted by alim@Jan 29 2006, 02:10 PM
[post=13639]Quoted post[/post]
