resistor used to convert 220V DC to 12V DC
ruleworld
Joined Jun 9, 2006
22
i made a pwm inverter which takes a little portion of the generated
220V AC voltage as reference. the 220V AC is rectified with 1N4007
bridge and given to the ic using a 220K Ohm resistor. is it safe to use
a resistor this way to step down 220V DC? the ic operates at 12v dc.
Gadget
Joined Jan 10, 2006
614
Circuit please.
I assume the divided 220 volts is for reference for regulation purposes rather than supplying Vcc for the ic..??
Again, circuit please.
To use a resistor to drop a voltage for supply purposes is dodgy at the best of times for reasons of Safety, poor regulation, inefficiency, and the potential of smoke damage.
ruleworld
Joined Jun 9, 2006
22
yes u are right the voltage is for reference. i run the inverter without connecting that and it runs but no pwm control.
the circuit is in a book, sry.
Prodigal
Joined Oct 12, 2006
10
Hi ruleworld,
I can't quite see what the purpose of this feedback is, but from your diagram it seems although the said voltage is merely being used to drive an optocoupler in order to switch a lower voltage to be presented to the IC. The 220k resistor seems to be there to limit the current to 1mA, which would be enough to fully saturate the phototransistor.
If this is the case then yes, this circuit should be perfectly safe as long as you build it correctly, observing proper safety precautions and keep your fingers out of the way.
Prodigal
Joined Oct 12, 2006
10
You probably worked it out for yourself, but I forgot to mention that you should keep in mind that the resistor needs to be able to dissipate 0.22W, so it's probably best to use one rated to 0.5W.
Søren
Joined Sep 2, 2006
472
2 of the half value (and 0.25W should do) is safer, as the voltage over each resistor will then be well within their 200V limit.
