Resistor Rated equivalent?
JVPszn
Joined Mar 16, 2019
Is a 680R resistor the same as a 680 Ohm resistor? I tried to look for the 680R resistor on Newwark electronics but the site is crashing and then tried to look on Mouser but I don't see any resistors that say 680R.
bertus
Joined Apr 5, 2008
23,005
There are some conventions used in schematic.
You will see the R as in 680R wich means 680 Ohms.
The R can also be in the middle of a value as in 6R8 wich means 6.8 Ohms
Bertus
jpanhalt
Joined Jan 18, 2008
11,087
