Resistor on a 48V charger?
kje
Joined May 6, 2012
27
What kind of resistor do I need here? I know the capacitor on C6, but what number is on the resistor? R18? And ohm?
22,112
Do some reverse engineering of the circuit and it may be possible to suggest a value.
What @MaxHeadRoom means is that if you examine the board carefully you may be able to create a schematic. From that schematic, the design can be compared to similar designs, and the value of R18 can be determined with some level of precision. Are you up to the task? It won't be easy.
30,815
By the wire gauge and outline size and the proximity to the missing electrolytic, I would guess it is in the circuit in or around the power input /DC supply/bridge rectifier part of the charger.
