Resistor Info
kbxc20
Joined May 27, 2015
11
Any one seen a resistor like this.
0.47 ohm 2 watt I assume. However it powers a circuit that is 12 volt DC with a 1.21 amp load flowing thru this resistor.
I can't see how this size resistor can carry this load unless someone knows otherwise.
It blew along with a transistor. I replaced the transistor and this resistor with a wire wound 5 watt which blew from overloading.
Other wise circuit seems to work ok.
ErnieM
Joined Apr 24, 2011
8,415
1.21 amps thru a A .47 ohm resistor is just 1.21*1.21*.44=0.7 watts.
So a 2 watt resistor should be quite fine here.
ErnieM
Joined Apr 24, 2011
8,415
I don't. Neither should you.
If you put 12V across .47 ohms you get 25.5 amps.
I assumed all of the current was going thru this resistor so the power is I*I*R
kbxc20
Joined May 27, 2015
11
This is the amount of amperage flowing THRU the resistor, not as if you if you connected each end of the resistor to the power source.
32,840
I get 14.52 watts 12Vx1.21A=14.52W
You are making the common mistake of throwing the nearest voltage and the nearest current at an equation just because it needs a voltage and a current.
P = V·I requires the voltage across THAT device and the current through THAT device in order to determine the power dissipated by THAT device.
kbxc20
Joined May 27, 2015
11
Thanks to all replies.
But back to the original post. The values stated are actual operational measurements. The resistor is just in a series circuit with other components.
All I know is that it now blows 5 watt wire wound ceramic case resistors after about 2 minutes
whereas the one in the picture lasted for 4,745 hours. Again is this one made differently or is the current and voltage stated too
high for the resistor in question. (see pic of disassembled resistor)
32,840
I would say that something has gone wrong with the circuit such that the "other components" that the resistor is in series with is now presenting a much lower effective resistance to the supply so that you are getting more voltage across (and hence current through) that resistor.
What is the voltage measured directly across the resistor when it is in operation?
