Resistor identification
AlbertHall
Joined Jun 4, 2014
12,625
I have a (faulty) resistor: Black, Brown, Green, Silver, Brown - 0.15Ω?
It is about 18mm x 5mm.
It is in series with a battery being charged at 2A.
I need to replace this.
Did I get the value right?
Is it anything special?
What wattage do you think it is?
I believe it is a shunt for measuring the current to operate the circuit which works the red/yellow/green LED.
upand_at_them
Joined May 15, 2010
939
Resistor codes don't start with zero. They are a version of “standard form”, a number between 1.00x10^n and 9.99x10^n, where n is the multiplier band.
How should 0.15 ohms be represented in 5-band code? Maybe the manufacturer (Chinese?) didn't follow standard form? I'm playing Devil's advocate.
sagor
Joined Mar 10, 2019
1,049
When the multiplier is very low, 0.01 (silver), it would be hard to designate a low value of resistance without a leading zero in a 5 band color code. Think about it, if you forced one to use at least brown or more for the first band, how do you show 0.01 ohms? There is no smaller multiplier than 0.01 (silver), is there?
BobTPH
Joined Jun 5, 2013
11,515
Yep, any value < 1 requires a leading zero in the 5 band code. I was surprised at that, but it appears to be true.
Bob
Ian0
Joined Aug 7, 2020
13,132
Colour-coded resistors that low in value are rare, because only leaded resistors have colour codes. When the resistance is that low, the resistance of the leads is starting to affect the overall value.
I'm also surprised to see a 5-band code, because <1Ω resistors tend to run in an E6 series.
Another thought - if you ignore the initial black band, then it becomes a perfectly valid 4-band code.
AlbertHall
Joined Jun 4, 2014
12,625
It is a leaded resistor. It is open circuit and shows no sign of overheating or mechanical damage. The background colour is pale blue which made me wonder if it a fusible resistor.
Ya’akov
Joined Jan 27, 2019
10,235
It certainly could be but since the color code says 1% and blue is very common for 1% resistors, that seems to be the reason. On the other hand, if it is open, it lends some weight to your idea.
upand_at_them
Joined May 15, 2010
939
Got a photo? Could it be an inductor? Are there any obvious physical differences between an inductor and a resistor? The inductors I'm looking at on my bench right now have a pale blue background.
sagor
Joined Mar 10, 2019
1,049
Too bad the black wire hides the IC name.
I suspect it is a current shunt of some sort, and the rest of the circuit provides feedback as to overcurrent, etc.
There is nothing on that board that can handle any amount of "power", so it is strictly for monitoring I think.
