Resistor gets too hot
Bigbizkit
Joined Oct 29, 2015
44
Hi guys...
I have this old amplifier kit from like 5years ago. The IC is broken so I replaced it. Its a Toshiba TA8205ah.
Somehow i managed to make it work. Monitored the IC temp, gets hot fast but i think the heatsink can handle it.
I powered it with a 12v 3A regulated power supply.
But after a minute i smell something, and then i noticed that the 10 Ohms 1/2W resistor gets extremely hot. That its color is almost brown already.
What could possibly be the problem? Somebody help plssss....
The image below is the output pin of 8205ah.
bertus
Joined Apr 5, 2008
22,990
Why do you use 10 Ohms resistors when the datasheet say 2.2 Ohm resistors?
Also why do you have 2 X 22 Ohms resistor in the speaker lines?
The amplifier has an high load wich might give problems.
BTW the datasheet you posted is for the TA8233 and not the TA8205.
I have attached the correct datasheet.
Bigbizkit
Joined Oct 29, 2015
44
I bought it as a Kit sir.
I bought it as a kit sir.
Uhm so what do you think i should do sir?
R!f@@
Joined Apr 2, 2009
10,007
A scope can check if AMP is oscillating.
With a VOM there is not much you can do....but you can check the electrolytic caps for leaks if you know how to.
If you don't next option is to replace all the electrolytic caps, since from the pic I see that things is OLD.
Bigbizkit
Joined Oct 29, 2015
44
If you don't I will replace all the electrolytic caps, since from the pic I see that things is OLD.
Ukie! Yes sir! Ill do that! Thank you!
DGElder
Joined Apr 3, 2016
351
I see there are 4 caps and 4 resistors circled? Are those all the R and C components in those two networks. Or are there 4 resistors for each RC network? I ask because ( assuming your schematic notes the single component values and not the network equivalent) 2 caps in series and 4 resistors in parallel would match the recomended RC values for each network. If only one network is getting hot that would provide a big clue as to where the fault lies - probably in those cap/s.
The R/C values are important for proper phase shifting to prevent oscillations. A fault in that network could cause oscillation as well as overload of the resistor.
bertus
Joined Apr 5, 2008
22,990
The test circuit shows 0.12μF capacitors with 2.2 Ohm resistors:
You are using 0.22 μF and 10 Ohms.
DGElder
Joined Apr 3, 2016
351
My schematic only shows 1channel. 1cap in series with resistor for every output of IC. (Pin 11,12 and pin 15,16)
So there are four rresistors and 4caps.
Sorry, I wasn't paying attention. Then the values are quite different from the recommended values - giving 5x the resistance and 1/2 the reactance, so I would look at them with suspicion. There will be interplay between the choice of C2 (47uf recommended) and these 4 RC networks.
The other thing is the confusion over datasheets and part numbers. Did you replace the IC with the exact same part and if not what are the differences in specs and recommended parts?
In any case if it worked when you bought it and it doesn't now, then I guess it's hunt peck and swap till you find a faulty part. Not having a scope limits what you can do. Good luck.
