There are very good capacitive humidity sensors available, but they require some skill in making them work well.Is there any resistive humidity sensor that I can power with a dc voltage and with analog output not digital? I prefer araw sensor not a module.
With many types of resistive sensors, it is recommended that you apply AC voltages in order to prevent polarization. You can implement this on an MCU by connecting the senor to two GP I/O digital pins and switching the outputs of the pins in an H-bridge configuration. Add a capacitor in parallel with the sensor and measure RC pulse duration or frequency. No ADC is needed because you are essentially performing your own A/D conversion.Is there any resistive humidity sensor that I can power with a dc voltage and with analog output not digital? I prefer araw sensor not a module.
| Thread starter | Similar threads | Forum | Replies | Date |
| A | Resistive vs capacitive dropper for 230V AC button sensing | General Electronics Chat | 54 | |
| C | Dehumidifier humidity sensor | General Electronics Chat | 14 | |
Voltage drop across resistive load to current source | General Electronics Chat | 4 |
