Request for help in repairing Technics SU-V90D
35,178
You are doing something wrong. As far as I can see, the curved side is against the pressure clip for both transistors.
The flat side faces the main heat sink.
Danko
Joined Nov 22, 2017
2,236
Then why does TS not install the replacement in same orientation if the replacement has the same pinout?
Before replacement, TS checked pinout in datasheet and see discrepancy between pinout and silkscreen.
So, questions:
1. What, in reality, was original orientation?
2. This metal thing is "heatsink" or it is some mechanical part? Some clip?
35,178
So, questions:
2. It metal thing is "heatsink" or it is some mechanical part?
I don't know what discrepancy TS found. I see no discrepancy with datasheet, PCB holes and silkscreen.
The metal thingy is a pressure clip to push the transistor's flat face against the metal back plate "the heatsink".
You can see in the photo, heatsink compound between the flat face of Q551 and the "heatsink".
Danko
Joined Nov 22, 2017
2,236
original Japanese transistors used in locations like Q551 require the flat side to face backward toward the thermal clip and heatsink while maintaining the E-C-B pinout from left to right.
Yes, pinouts are identically, all is good, TS is not right.
35,178
One possible source for confusion is that the Technics Service Manual for SU-V90D shows the circuit board as viewed from the solder side. Yet, they reversed the component reference designators so that you can identify the component. This is not the silk screening that one would find on the component side of the PCB.
Here is the image of the PCB as viewed from the component side.
35,178
With Q551 removed, check for valid NPN diode functions with a DMM in diode test mode on both the original Q551 and the replacement transistor.
The next step would be to install IC501, Q557, Q559, and a fresh Q551.
Measure the voltages at Q551, Q557, and Q559.
KaMel88
Joined May 11, 2026
59
I checked the correct operation of the Q551 with a digital multimeter, the new transistor has the same values as the old one and is NPN
Transistor voltages:
Q551 - B: -0.4 C: 1 E: -1
Q557- B: 0,5 C: 53 E: 0
Q559- B: 0,5 C: -53 E: 0
Voltages IC501:
1 : -1
2 : -1
3 : -1
4 : -7
5 : 0
6 : 0
7 : -1
8 : 7
Should I install a new IC501?
35,178
Voltages IC501:
1 : -1
2 : -1
3 : -1
4 : -7
5 : 0
6 : 0
7 : -1
8 : 7
Not yet. The voltages look reasonable, except Q559 base should be -0,5 V.
I suppose the readings were taken with the lamp circuit.
What are the readings if you remove the lamp circuit?
KaMel88
Joined May 11, 2026
59
voltage without bulb :
Q557- B: 0,5 C: 60 E: 0
Q559- B: -0,5 C: -60 E: 0 (I missed the minus sign)
35,178
When you can get 0 V at the emitters of both Q557 and Q559 you can do an audio test.
Turn the VOLUME control down to the lowest level. Connect a loudspeaker to the LEFT channel output.
Apply audio source and turn up the VOLUME control slowly. Do not test at high sound level.
Listen to the quality of the sound and listen for noise or distortion, or if you get any sound at all.
KaMel88
Joined May 11, 2026
59
Ok, the heatsink must be installed to the transistors?
35,178
Not necessary if you keep the test short and at low volume. Check the temperature of the transistors with your finger as soon as you turn the power on. Turn off immediately if the transistors are too hot to touch. (I use a thermal imaging camera when I do these tests.)
To be on the safe side, you can add individual cooling fins to Q557 and Q559. Do not allow the metal fins to touch each other or any part of the amplifier and chassis. Keep the fins isolated from everything else.
KaMel88
Joined May 11, 2026
59
I'm asking because they heated up very quickly during the measurements. For safety reasons I will install a heatsink
KaMel88
Joined May 11, 2026
59
The left channel works. Music sounds good, without distortion, and I listened for about 15 minutes. I also used a thermal imaging camera. The transistors remained cool throughout the test, with only the bridge rectifier area exceeding 100°C.
35,178
That is good news. Now you have a working LEFT channel by which you can compare voltages with the bad RIGHT channel.
Use the lamp circuit at this stage to limit the current.
Start by measuring the voltages at TP402 to make sure that they are close to 0 V.
Install the missing components and check the voltages at the transistors.
Measure the resistors before installing. Do a diode test on the transistors before installing.
Key voltages we are looking for are:
Q558, Q560 emitters, Z552 should be 0 V.
IC502 pin-8, 7 to 8 V
IC502 pin-4, -7 to -8 V
Q554 base, about 1 V
Q556 base, about -1 V
KaMel88
Joined May 11, 2026
59
1. Should I install the removed items all at once or in stages?
2. I have to assemble the Z552 resistor from two: https://www.digikey.nl/en/products/detail/te-connectivity-passive-product/SQPW5R22J/2365728
Do I need to do the same thing in the left channel later?
35,178
1. Normally, it is best to do it in stages. However in this case, there is DC feedback involved in this circuit. So we have to take the chance and hope that all the components are good.
2. No. Leave the LEFT channel as is.
